Runnning Rough
Old Sep 19, 2013 | 07:51 PM
SLV's Avatar
SLV
Originally Posted by target64
have your fuel pressure checked, sounds like fuel pump acting up!!
I agree. I'd hold off on changing the plugs and wires until you isolate the issue.
Old Sep 19, 2013 | 08:06 PM
soft 02's Avatar
soft 02
Bad TPS sensor. Your welcome.
Old Sep 19, 2013 | 08:31 PM
bobnehoc's Avatar
bobnehoc
[QUOTE=JonV;11784365]In response to a two points, as stated in the OP bike is Stock. No code indicated by the security "Key" light.
The Security Key Light is for Security. The only time my Key Light was flashing was when the bike was moved and the Fob was not near by. It does not light up if there are any stored codes. You will have to check manually for any codes.
Old Sep 19, 2013 | 08:44 PM
nevil's Avatar
nevil
That, or a hole in the fuel line in the tank. I doubt it's plugs and wires.
Old Sep 20, 2013 | 04:23 PM
JonV's Avatar
JonV
Default Solved
Whoa.... this is sort of embarrassing... This Spring I changed my fluids, the previous fall I had my bike in the shop and was charged for an air filter while having repairs done. Apparently they did not change the filter. A friend suggested I check the Intake.. he was right, I can't believe the condition of the filter. I was thinking it was only 11 mos old... put in a new one and it runs like a champ.
Old Sep 20, 2013 | 04:49 PM
nevil's Avatar
nevil
Lesson learned. Now you know to check your bike after it's serviced. Better yet, get a manual and do the work yourself. Start with the easy stuff. Changing an air filter takes about 5 minutes.
Old Sep 20, 2013 | 06:13 PM
JonV's Avatar
JonV
Yeah, I've done the filter before before and did it this morning, threw in plugs this afternoon and Fat wires. I do my own fluids because on other occasions I've come up a bit light from a dealer.
Old Sep 20, 2013 | 06:33 PM
mirrmu's Avatar
mirrmu
Hi,
Good result man
Thanks
Mirrmu
Old Sep 20, 2013 | 07:14 PM
bdtaylor1979's Avatar
bdtaylor1979
Thats why I do my own services, the dealers/shops don't always do what they are supposed to do/charge you for.
Old Sep 22, 2013 | 11:59 PM
The Outlaw's Avatar
The Outlaw
my bike (07 wide glide) just did the same thing on the 21st during a benefit ride. i just assumed it was water in the intake from letting it sit out in the rain uncovered. guess i might want to check my filter.
