Runnning Rough
Old Sep 19, 2013 | 02:01 PM
JonV's Avatar
JonV
Unhappy Runnning Rough
Hi guys,
Last week or so I've had some difficulty with starts while the engine is still hot, new battery last month, starts fine cold. Now today while cruising in 5th, intermittent multiple backfires then lunges. Then died at a stoplight. Any insight before I get it to the Dealer? Help would be appreciated.
2009 Stock FXD only 7500 miles
Thanks, John
Old Sep 19, 2013 | 04:10 PM
JonV's Avatar
JonV
Default No One?
No comments at all? I've checked the battery cables plugs/coil wiring, changed the air filter. Hoping it's not the Stator.
Old Sep 19, 2013 | 04:14 PM
BC45's Avatar
BC45
You don't say if it cranks, or if it cranks but does not start? hard to comment when no info. What is batt voltage?
Old Sep 19, 2013 | 04:18 PM
Wranglin4Life's Avatar
Wranglin4Life
Does your bike happen to be under warranty? If you have checked all the obvious things which it sounds like you have then I would take it in.
Old Sep 19, 2013 | 04:27 PM
JonV's Avatar
JonV
Not under warranty, bike restarted after it died... ran 2 miles home, pop and sputtered again while accelerating (not on decell). Started it up a while ago, idles fine, revved up fine. gonna test ride it a bit in a while. Don/t have a meter handy...
Old Sep 19, 2013 | 04:54 PM
fskitch's Avatar
fskitch
Doyou have a power comander? If so take it out of the loop and see if the problem goes away. Happened to my bike with similar syptoms.
Old Sep 19, 2013 | 06:03 PM
bobnehoc's Avatar
bobnehoc
Have you checked for codes? These bikes are so loaded down with sensors and electronics that if something goes wrong trouble codes are logged. These codes if any, will really make it much easier to diagnose and fix the problem.
Old Sep 19, 2013 | 06:32 PM
bdtaylor1979's Avatar
bdtaylor1979
I had a similar issue on my 07 super glide and it ended up being a bad hose/o-ring on the fuel pump inside the tank. I hear its a common issue on these bikes.
Old Sep 19, 2013 | 06:46 PM
JonV's Avatar
JonV
In response to a two points, as stated in the OP bike is Stock. No code indicated by the security "Key" light.
Have an Indy coming to check it out tomorrow. Also installing fresh plugs and SS Fat Wires.
Old Sep 19, 2013 | 07:15 PM
target64's Avatar
target64
have your fuel pressure checked, sounds like fuel pump acting up!!
