over heating
Old Mar 11, 2007 | 06:58 PM
hd4ever's Avatar
hd4ever
3rd Gear
Default over heating
i need help i ride a 96 dyna wide glide no matter what i do it over heats in traffic ive added a lockhart oil cooler smaller filter bigger filter royal purple synthetic oil daytona bike week main street stop and go the bike pings gets nasty hot.. can some one steer me in the right direction.. thaks tattoo
Old Mar 11, 2007 | 07:24 PM
Dirtrace95's Avatar
Dirtrace95
Default RE: over heating
Did you get a stage 1 down load, or better yet a tuner to richen things upi ??? Its just too lean
Old Mar 11, 2007 | 07:36 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
You might want to have your oil pump pressure checked. Also, what oil filter are you using as the new filters might be restricting your oil flow. I am assuming your bike is carbed. Did you do any mods to the carb?
Old Mar 11, 2007 | 07:39 PM
randy78045's Avatar
randy78045
You state the bike pings... that's a result of running lean... and that will destroy an engine ina heart beat AND cause the engine to run hot... get a tune...
Old Mar 11, 2007 | 11:33 PM
hd4ever's Avatar
hd4ever
3rd Gear
thanks for all the help guys the only thking ive done is take the big 8 inch round air cleaner off and the filter and put on a after market s&s tear drop air cleaner and filter and of course ive changed the plugs to screamin eagle hi pro plugs and the wire the oil filter iver tried 4 diffrent kinds i have a fram on there now ive used 2 harley filters one small and one large then a wic filter now this longer fram one and i just had this lockhart oilcooler installed thinkin that would help i do have a 2 into 1 harley header pipe and muffler with no baffle in it .. other than that jus a lot of chrome ..
[IMG]local://upfiles/26720/7BF4B1930CC54DB9A22D6F784DF837AF.jpg[/IMG]
Old Mar 11, 2007 | 11:57 PM
but Ill try 2 try's Avatar
but Ill try 2 try
Your intake flows somewhat more air than your stock one, but your exhaust flows way more. You couldn't have done a better job of making your bike lean if you tried. Which I guess you did, so good job. I don't know if you're referring to a 1996 bike or a 96inch bike but either way rejet or remap respectively.
Old Mar 11, 2007 | 11:58 PM
mtnlvr's Avatar
mtnlvr
If you,ve never done anything with jetting of the carb, your aftermarket air cleaner and free-er flowing exhaust are definitely making it lean.
Old Mar 12, 2007 | 12:00 AM
hd4ever's Avatar
hd4ever
3rd Gear
its a 1996 dyna 1340 so my scoot needs a shop good job me huh.. thanks for the help fellas
Old Jul 11, 2008 | 10:56 PM
pjpockets's Avatar
pjpockets
something else also. check for vacume? leak at intake manafolds. spark plug color on one plug would be white.
Old Jul 11, 2008 | 11:39 PM
96 Wide Glide's Avatar
96 Wide Glide
Also, Run the extra long HD oil filters your bike came from the factory with. Bigger filter holds more oil... better cooling.
Make sure it's the xlong filter for an EVO. The valving is different in the twin cam filters.
&nbsp\\;
Cheers... Ben.
