Bungking bracket help
Old Nov 16, 2013 | 10:43 AM
ian01's Avatar
ian01
Default Bungking bracket help
Can someone tell me how much of the hardware I use from the HD fairing kit? Obviously I use the (6) screws that bolt the HD bracket to the fairing and all the parts that attach the windscreen/headlight cover.
I see the bungking kit comes with 4 bolts with no nuts- I assumed those were meant to attach HD bracket to bungking bracket....
Thanks!
Old Nov 16, 2013 | 11:05 AM
SquidHead's Avatar
SquidHead
Thanks!
I just responded to your PM, but after reading this, I think I better understand your question.
You don't need nuts if you use the HD quick detach clamps recommended by Bung King. The bolts they supply connect the clamps to their brackets.
Here's a pic from an old classified of the bolt hole side of the clamp:
Here's a shot of them clamps mounted to the brackets and fairing on my bike:
I have a thread of how I did my quarter fairing that might help you.
https://www.hdforums.com/forum/dyna-...g-project.html
Old Nov 16, 2013 | 11:24 AM
ian01's Avatar
ian01
Ok- so the (4) stainless bolts supplied with bungking go with my HD clamps.
So I'm assuming I use 4 bolts from HD hardware to attach bungking bracket to HD bracket.
Thank you!
Old Nov 16, 2013 | 11:33 AM
SquidHead's Avatar
SquidHead
Thank you!
No, you use the 4 BK bolts to attach the HD clamps to the BK brackets. The BK brackets attach to HD fairing using the HD hardware from the HD kit.
Old Nov 16, 2013 | 11:39 AM
ian01's Avatar
ian01
Right- do you recall whether the spring mechanism hardware is used
Old Nov 16, 2013 | 01:45 PM
SquidHead's Avatar
SquidHead
I didn't use any of that stuff, just the 4 short black adjustment nuts and bolts from the HD kit to connect the fairing to the BK brackets.
rysonn
May 17, 2019 09:15 PM
diggerdave70
Jan 22, 2019 08:40 AM
04Fxdl87
Jun 22, 2016 08:25 AM
ajmilberg
Nov 23, 2014 08:16 PM
iclick
Sep 24, 2014 10:19 AM
