Speedometer Error Code
Old Mar 7, 2014 | 07:49 PM
05dynaman's Avatar
05dynaman
Default Speedometer Error Code
I just installed New Air Cleaner and Exhaust and also an arlen ness cheap shot tuner( which i think is what tripped it...)
I started the bike up and everything works fine except for the speedometer and the red key light is on. Also when i was installing the turner i disconnected the battery all the way to get a dropped socket.
Bike runs good. I ran the diag mode and i got the
SP code
U1255 Missing Message at Speedometer EFI
U1255 Serial Data Error/Missing Message EFI
U1255 Serial Data Error/Missing Message Instruments
U1255 Serial Data Error/Missing Message TSM/TSSM
Is this something i have to take to the dealer to get reset and fixed or is this a DIY easy job.
Old Mar 7, 2014 | 09:14 PM
nevil's Avatar
nevil
I don't know how that tuner works, but before bringing it to a dealer I would check the connection and pins. Then pull the tuner and see how it runs and if it still throws codes.
If you can clear the codes and they don't come back, it could be a defective unit or wrong settings.
Old Mar 7, 2014 | 09:19 PM
QC's Avatar
QC
I ran a Ness Cheap Shot on my '04 Softail and never threw a code. In fact it is still on the bike but disconnected in case the PCIII ever pukes. You may want to check your connections.
LUEPNITZ
May 8, 2013 04:07 AM
Inspector 12
Jun 24, 2011 12:35 PM
justa2z
Oct 17, 2010 06:37 PM
saw*me
Apr 18, 2009 04:22 PM
J Short
Exhaust System Topics
Jun 11, 2007 07:56 AM
