Brake light stays on
Old 04-27-2014, 08:53 AM
jhensley3300's Avatar
jhensley3300
jhensley3300 is offline
6th Gear
Default Brake light stays on
89 fxr brake light is lit all the time. I don't know where to start. I believe everything worked as it should until I installed a new throttle tube (but I'm not sure). I also recently changed my headlight. I think I've screwed something up in one of those two places... Any tips on what and how to check it?
Old 04-27-2014, 09:05 AM
Northern Glide's Avatar
Northern Glide
Northern Glide is offline
Received 3,914 Likes on 2,813 Posts
First thing I would check is your front brake stop light switch. Is it functioning properly? Mine got sticky on a 99 sporty and would stay on.
Old 04-27-2014, 09:26 AM
RANGER73's Avatar
RANGER73
RANGER73 is offline
Received 6,028 Likes on 3,073 Posts
Any work done on the bars?
First thing I'd do is unplug the wires from the rear foot brake switch on the master cylinder and see if it goes off. If not, it's the front switch in the housing with the start button, that one's a bitch to replace.
Old 04-27-2014, 09:45 AM
TexasScooterTrash's Avatar
TexasScooterTrash
TexasScooterTrash is online now
Received 1,252 Likes on 768 Posts
You installed a new throttle sleeve and missed a step putting it back together. You need to hold the front brake lever in while tightening the control/clamps. The front brake lever is holding your switch on.
Old 04-27-2014, 10:04 AM
rooti's Avatar
rooti
rooti is offline
Yep thats it. Take the brake lever off and push in the little micro switch underneath and turn on the ignition and watch the brake light go off. Sometimes if you don't have the brake lever in the exact position it won't hold the button in. Button in is what shuts off the brake light. When the button is out the brake light comes on.
Old 04-27-2014, 05:40 PM
jhensley3300
6th Gear
I unplugged the rear and brake light still stayed on. When I changed the throttle sleeve I don't think I messed with the brake at all. Can't. Remember but I will check that next but my throttle and brake are separate.
Old 04-27-2014, 06:41 PM
jhensley3300
6th Gear
Thank you Texas Scooter Trash and rooti!!! Problem solved!!!
Old 04-27-2014, 08:20 PM
Andjh123's Avatar
Andjh123
Andjh123 is offline
Keep an eye on that switch as you rack up the miles. I think it was around 35 or 40k miles on mine that vibration/general wear and tear had worn it down enough that it no longer made sufficient contact to keep the light off.
Old 04-27-2014, 09:04 PM
jhensley3300
6th Gear
Thank you Texas Scooter trash!!! Problem solved!!!
Old 04-27-2014, 09:06 PM
jhensley3300
6th Gear
Thar fixed it. Thank you rooti!!!
Quick Reply: Brake light stays on
