Performance upgrade
Old Jun 18, 2014 | 04:56 AM
Apollo/Dyna's Avatar
Apollo/Dyna
6th Gear
Smile Performance upgrade
Will it increase performance enough to take my 96c.i. dyna to 103. or would 110 be a better upgrade?
Old Jun 18, 2014 | 05:04 AM
target64's Avatar
target64
107 cid with the correct setup will get u into the 120 hp range for performance. if you go for a 110 your cases have to be bored why stop there go for a 124!!!
Old Jun 18, 2014 | 05:21 AM
atrox88's Avatar
atrox88
What Target said. I would consider the Fuel Moto 107.
Old Jun 18, 2014 | 07:44 AM
ghira75's Avatar
ghira75
The FM 107" seems to me the best choice. Highest cubic inches possible without boring the cases. It's a mod that many here have done so there's plenty of testing done, FM has for sure the right maps already worked out for many different pipes/AC+cams combinations on the 107".
I'd definitely go for the 107". If I'd have to bore, then Id' definitely consider 124-131" something crazy like that.
Old Jun 18, 2014 | 10:39 AM
latrobedyna's Avatar
latrobedyna
Yep i go to a 107 if i was doing it. If your going to Z&M however to have work done be prepared to get a lot of grief as they frown on doing any kind of a put a smile on your face mod I would highly advize you to call or go talk to
McClain's Jam Cycle (724) 593-1369 This guy is awesome !!!
Old Jun 18, 2014 | 04:47 PM
Apollo/Dyna
6th Gear
Thanks everybody, really helps. Latrobedyna I do not go to Z & M unless I have too. I purchased bike from Hot Metal!!
Old Jun 18, 2014 | 05:02 PM
target64's Avatar
target64
how far from hillside cycles are you. scott and craig can have that think honking!!!
Old Jun 19, 2014 | 01:43 PM
bigdaddy33's Avatar
bigdaddy33
107" as others have said is a good way to go. Cost wise, it's a good bang for the buck. Once you start going bigger, 117", 124", the cost goes up a lot.
jeff.georgalas
Exhaust System Topics
45
Mar 18, 2020 04:33 PM
saintdaniel
Jul 12, 2012 11:57 PM
dbrown5
Jan 17, 2012 01:46 PM
jtomhd
Oct 6, 2010 06:35 PM
scooby doo
Nov 16, 2009 04:17 PM
