Day 9 - learning by doing
Thanks to Jeff's 1st Harley for the tip on the Michelin Commander II tires. These tires made my bike ride light, and so deceptively easy. Sure wouldn't think I was on a big 'ol Harley ...
Honestly - I feel more ... secure on the FXD than I did on any other bike, in a very long time. I'd have to go back to the Nortons to feel as confident as I do now.
I am brand new in here. Don't know much yet! My repair manual is somewhere... not here yet. Still, I have been trying to fix my bike up.
I changed the plug wires and installed standard NGK plugs, until the iridium ones arrived. I installed the iridium today (DCPR7EIX).
They say those plugs are "pre-set" and not to gap them. I say bologna. I used regular, slip-joint pliers to bend the outer electrode away from the center electrode, then set the gap at .040 inch, without stressing the center electrode.
WHAT A DIFFERENCE!
The motor idled faster. That was the first thing I noticed. It took the computer a few miles to catch on, then the idle slowed down to almost what it was. Almost all the phardting out the exhaust is gone, as is the rolling miss at part throttle and low speeds. The idle is much more steady. The "Harley lope" is still there - just not as much.
I also learned that a large master padlock fits nicely into the slots in the rear brake rotor. If somebody wants the bike they'll have to carry it, 'cause the back wheel sure won't turn!
I don't just take. I try to give something, as well
WHAT A DIFFERENCE!
I'm gonna have to look for that hole - the damn thing's heavy to carry around in my pocket! Of course I could always get a bandana and carry it in my back pocket, aka an infamous club...
Not trying to insult anyone's intelligence but when you put it on the rotor make sure you have a "visible reminder" that you will see before you take off. Like a flag that an aircraft uses to remind them covers are in place. Everyone has a brain fart once in a while.
True dat, I used to have a "Remove Before Flight" lanard on a key ring I would put on the lock when using locking the front disk. Apperently, someone are Rolling Thunder felt they needed it more than I did a few years back and cut it off the lock, just havent gotten a new one yet.
I found it - rofl - but I use a much bigger lock - so much so I wonder if this hole will allow it to bang on the motor. Guess I'll find out
I rode a V-rod today! Cat was trying to sell it. I didn't like it, at all. Drag racer - in my mind, good for nothing else It did scurry right along, though!
