Security system
Old Mar 8, 2018 | 04:36 PM
Spur2018's Avatar
Spur2018
6th Gear
Default Security system
I just purchased a 2004 Road King Classic. Paper work indicated a security system was installed when purchased originally. I did not receive a key fob and the bike starts normally. The red key light comes on temporarily until bike starts and then goes off. How can I determine if the system is still on board. I had a key fob from from a 2003 Heritage that I owned previously but could not get anything to happen when I tried to activate it.
Old Mar 9, 2018 | 07:01 AM
Campy Roadie's Avatar
Campy Roadie
Pull the right side cover and look at the part number (on your bike) of part number 10. One is a TSM and the other is a TSSM (security).
http://partsfinder.onlinemicrofiche....UIT%20BREAKERS
Old Mar 9, 2018 | 10:08 AM
Spur2018's Avatar
Spur2018
6th Gear
Ok I do have the security module TSSM installed. looking at the fuse panel and cannot locate a fuse for the security system.The owners manual does not identify it either. What is P&A fuse for? The top right fuse panel cover has melted and could not read what was once there. I have 8 fuses installed and all are good which is what the owners manual shows. I may need to purchase a key fob.From what I have read I should be able to manually activate the system but that failed also.
Old Mar 9, 2018 | 12:27 PM
Campy Roadie
If it was me (and it's what I did) I'd get a TSM off Ebay or Boardtracker HD, switch them out and call it good. On the early button systems you don't need the dealer for anything; the bike will start right up.
Old Mar 9, 2018 | 12:35 PM
Zanthamos's Avatar
Zanthamos
Going from the TSSM to the TSM will require the password relearn proceedure described in one of the stickies or in your FSM, without any FOB I don't think there is a way to program a new FOB so if you want the secutity system you will need to replace the TSSM and do the password learn proceedure. If I am not mistaken the P&A fuse is for accessories, but without looking at the wiring diagrams I cannot say definitively.
Old Mar 9, 2018 | 01:19 PM
Campy Roadie
It absolutely did not involve anything other than disconnecting the power from the battery, letting it sit a night, then unplugging the TSSM, installing the TSM and reconnecting the battery on my 2002 which is the same system. That's why I said it didn't.
The procedure does need to be followed for the hands free systems or the dealer can take care of it with DTII. You're right about the P&A fuse.
Old Mar 9, 2018 | 02:41 PM
Zanthamos's Avatar
Zanthamos
Do you have an EFI or Carb model, stock or aftermarket ECU or ICU?
Old Mar 9, 2018 | 03:13 PM
Spur2018's Avatar
Spur2018
6th Gear
Thanks for all your inputs. I retraced my steps and was able to activate the security system using the FOB I had from previous vehicle. Seems if you skip a step in the OWNERS MANUAL procedure it doesn't work..Imagine that..Thanks for your help. Posted pictures of my bikes in the gallery'
Old Mar 9, 2018 | 04:59 PM
Campy Roadie
My 2002 is carbed and the bike is completely stock but for an intake and 2 into 1 exhaust.
Old Mar 9, 2018 | 06:16 PM
Ed Ramberger's Avatar
Ed Ramberger
delete
