Throttle by wire Hard wiring help On 16 FXLDS
Old Feb 11, 2019 | 11:06 PM
Jlohojo7's Avatar
Jlohojo7
Stage II
Default Throttle by wire Hard wiring help On 16 FXLDS
I need help hard wiring this bc the idiot before me cut all the plugs off. Everything else has been very easy and color coded but this has 2 reds 2 whites and 2 blacks all in the same plug. How in the world can I distinguish which goes where? Can anyone help me in doing this? Please help me out. It’s on a 16 dyna low rider s
Old Feb 11, 2019 | 11:11 PM
TriGeezer's Avatar
TriGeezer
It would probably be most helpful to get a Factiry Service Manual for the schematics.
Old Feb 11, 2019 | 11:24 PM
Jlohojo7's Avatar
Jlohojo7
Stage II
Even if that shows me where they go to how am I suppose to determine which red is which which black is which and which white is which. Why didn’t they just make them different colors or striped ? Thoughts for determining what’s what? Or does it even matter as long as the colors are together?
Old Feb 12, 2019 | 10:04 AM
Zanthamos's Avatar
Zanthamos
Go here https://serviceinfo.harley-davidson.com/sip/index and look up your bike, you can get the wire diagrams and in the wire diagrams it will give you both ends of each wire so you can see what pin on the other end it goes to to id what pin it would go to in the plug that you are trying to fix. For example, P1 red pin1 to P5 pin 3 and then P1 red pin 5 to P7 pin 7. I would be easy to differenciate between by just following the wiring diagram and using a multi-meter to check for continuity in the wires.
CheneyColin
Electrical/Lighting/Alarm
Sep 12, 2018 02:11 PM
bigpappa160
Aug 26, 2018 08:23 PM
Mattster
Feb 9, 2017 08:02 AM
sixshooter
2014-2024 Touring Models
Jan 23, 2015 05:34 AM
Munkee
Audio Systems
43
Aug 16, 2014 12:22 AM
