Eagle Lights
Old Feb 12, 2019 | 09:26 AM
ngjandm's Avatar
ngjandm
6th Gear
Default Eagle Lights
Anyone have any experience with Eagle Lights LED headlamps? Not many choices out there for the Fatbob Dual Headlight smaller lamp setup. Daymakers just way too pricey, Kuryakyn doesn't appear to make them. I have Ciro3D LED turnsignal replacements on my 2010 FXDF, they don't make them either. I've looked at some reviews of Hogworkz as well, curious if anyone has any experience with Eagle Lights.
Old Feb 17, 2019 | 05:04 PM
ngjandm's Avatar
ngjandm
6th Gear
I guess that sounds like a no. Anyway, I did some reading on a few brands, and did purchase these Eagle Lights. So I'll let you all know what I think. I won't be able to compare them to anything other than stock, but at least I can write about what I think of them.
Old Feb 27, 2019 | 11:49 AM
M1chael's Avatar
M1chael
I too am interested in Eagle's products. I'm very curious about your experience with them.
Old Feb 27, 2019 | 12:10 PM
ngjandm's Avatar
ngjandm
6th Gear
I'll let you know after I get them installed. was planning on taking some before and after photos or videos. I won't be able to compare them to any other solution as I don't have experience with that.
Old Apr 8, 2019 | 08:27 AM
ngjandm's Avatar
ngjandm
6th Gear
Finally got these installed. Unfortunately soon after I purchased them, I had to fix a failed rear brake switch, which in itself wouldn't have been so bad, but had to replace all the bleeder valves and flush out and bleed the brake systems. On top of that, had to get through cataract surgery in both eyes, so finally got them installed.
I wonder of Eagle and Hogworkz get their LED lights for the FXDF from the same place. There is a youtube video on someone having to dremel the hogworkz lights to fit the fatbob light housing. The eagle lights, I had to do the same thing, so its wasn't a direct plug-n-play replacement. Had to dremel down a few spots so that the new lights could sit flush in the house.
Once installed, being LED lights, they are of course so much better than the stock bulbs from a 2010 FXDF, the night usage is much brighter, as well overall whiter (having new lens in my eye of course also helped). As I mentioned above, I have no comparison to other brands of LED brands, but overall I am happy with this product.
Aowen
Electrical/Lighting/Alarm
Jun 23, 2019 05:54 AM
Kingface
May 12, 2019 02:49 PM
M1chael
Mar 14, 2019 10:30 AM
jwoitena
2014-2024 Touring Models
Aug 11, 2017 06:08 PM
razorseal
Aug 25, 2016 04:38 PM
