99 roadking serious electrical draw.
Old 06-15-2019, 07:48 AM
Fear Less's Avatar
Fear Less
Fear Less is offline
Stage III
Default 99 roadking serious electrical draw.
Ok this is my problem I got a fresh battery fully charged hook it to the bike battery reads dead unhook it from bike battery says charged. New stater new voltage regulator checked the power wires for shorts nothing. Any help here would be highly appreciated.
Old 06-15-2019, 07:59 AM
jbarr1's Avatar
jbarr1
jbarr1 is offline
First step is to get the battery load tested.
Old 06-15-2019, 08:09 AM
Fear Less's Avatar
Fear Less
Stage III
Done that good.
Old 06-16-2019, 05:57 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Dan89FLSTC is offline
Received 8,499 Likes on 4,612 Posts
You should have come here before you started troubleshooting by buying parts.
Connecting the battery is not instantly making the battery go dead (the cables would be on fire).
Tell us exactly how you are measuring the voltage.
What are you touching the voltmeter probes to?
Old 06-17-2019, 01:51 AM
Fear Less's Avatar
Fear Less
Stage III
Red to hot side of battery and black to negative side of battery.
Old 06-17-2019, 08:08 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Are you always touching the probes to the posts, not the battery terminals?
Old 06-17-2019, 09:38 AM
RANGER73's Avatar
RANGER73
RANGER73 is offline
Received 5,924 Likes on 3,022 Posts
Who's load testing the battery?
A battery can read good but will fail under load if it has a bad cell.
Dan89FLSTC (06-17-2019)
Old 06-18-2019, 08:52 AM
skinman13's Avatar
skinman13
skinman13 is offline
I experienced an intermittent discharged problem with a new MoCo battery a couple of years back...never could verify it was bad on a charger or load test, but I did verify that the rest of the system was good and replacing it fixed my problem. The local dealer I purchased it from did a warranty replacement with no questions.
Rogerson0522
05-29-2018 10:42 PM
oakmossy
2014-2023 Touring Models
10-13-2015 11:16 AM
JOW_103
12-29-2014 03:49 PM
nocoast
08-09-2012 04:24 PM
Marquezj16
09-29-2011 02:54 PM
Quick Reply: 99 roadking serious electrical draw.
