charging problem
Old Aug 6, 2019 | 08:52 AM
terrysillik's Avatar
terrysillik
Default charging problem
I have been trying to track down a speedometer problem, come to find out at 2000 RPM's it is charging a little over 18 volts which I think is to high, also noticed win I unplugged voltage reg. quite a bit of oil came out of connection, can oil migrate down the stator wires to plug? A test light between ground and reg. pins shows nothing but a digital meter shows .14 volts at each pin, is the reg bad? terry
Old Aug 6, 2019 | 08:43 PM
Ed Ramberger's Avatar
Ed Ramberger
That was actually common on XLs in the early 2000's. When they charge that high, the speedo usually stops working. They also pop bulbs. You need a voltage regulator. Verify the stator (electrical tests) and battery while repairing.
If it's an FL, depending on the year there was a lot of oil from the plugs, and they were relocated to the flat plate between the two front frame tubes - thought was oil won't run uphill.
I believe there is a sticky on charging system testing.
Old Aug 6, 2019 | 10:05 PM
Ed Ramberger
Forgot to mention - the speedo usually works fine when regulator is replaced.
Old Aug 9, 2019 | 11:41 AM
terrysillik
New regulator took care of everything! terry
Old Aug 14, 2019 | 10:41 AM
Ed Ramberger
Awesome!
extremeshot
Electrical/Lighting/Alarm
Sep 30, 2014 03:10 PM
BiggestDawg
Mar 7, 2011 04:07 PM
diiulio
Apr 22, 2010 04:01 PM
gdbro4
Jul 19, 2007 08:59 AM
Crockettman
Jun 1, 2005 10:35 AM
