TSSM, Code 34
Old Jul 7, 2023 | 10:09 PM
Mr390's Avatar
Mr390
Stage II
Default TSSM, Code 34
Hi all,
I have a 2001 Heritage Classic and when I turn on the ignition the 4 ways flash six times and nothing happens when pressing the start switch. All lights, instruments, signals and horn works. TSSM is throwing a code of 34. All wiring from the starter relay port checks out good. Starter relay and starter are good. Key FOB has a new battery and communicates with system and can arm/disarm. Power and ground at TSSM is good. Any suggestions?
Old Jul 9, 2023 | 01:01 PM
enodrano's Avatar
enodrano
Originally Posted by Mr390
Hi all,
TSSM Code 34 (starter output high):
Starter relay and coil are grounded via TSSM when disarmed and ignition on.
This code means the ground is from someplace else...short/hot wired..etc.
Starter relay could be bad (voltage present on pin 9)(Tn/Gn) when not starting engine.
Old Jul 10, 2023 | 12:40 PM
Mr390's Avatar
Mr390
Stage II
Thanks for the info. I have seen this and based on all of the testing I have done I can't figure out what is causing it.
Fern54
Jun 10, 2022 06:27 PM
Mopower
Milwaukee Eight (M8)
Feb 9, 2019 08:47 PM
rvdoc
May 26, 2017 10:51 AM
cunfuzed
Jul 3, 2014 04:33 PM
bboy57
Aug 16, 2012 01:14 AM
