they will all do the same. you can buy the leds with the resistor already in there.
you can make a load block that will take all of this into account and even without soldering into the harness nor cutting it.
I believe you can still find a flasher unit that will handle the LED turn signals without the load ballast. Pretty sure that the flasher units were used until Harley went to the CAN system.
