security issues
Old Mar 28, 2026 | 02:14 PM
jwcycles's Avatar
jwcycles
Stage III
Unhappy security issues
ok,,,2007 ultra classic 96 inch fuel injected throttle by wire,,,,,i have to have the fob right on top ,,literally right on top of tssm and antena mount for bike to start,,,,new battery in fob,,,3.9 volts do the tssm units go bad or anntena unit,,,,,kind of a pain to have have the fob hanging off the tssm unit to be able to start the bike
Old Mar 28, 2026 | 02:18 PM
MURPHCC1's Avatar
MURPHCC1
You dont have a throttle by wire, it's a cable on a 07
Old Mar 28, 2026 | 02:24 PM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
They go bad. I have 17 threads (Now 18) saved in a folder. Haven't heard they go bad slowly. There no replacement parts except the signal light non security after market replacement unless you can find a used one.
If it dies locked up, it's a big issue. I would not lock it unless I need that security awful bad.
Your FOB is the button one that requires you to set it isn't it? Didn't think you have throttle by electric wire either? Don't you have two wire cables off throttle? One to open and a safety to pull it back even if other was to break.
There post that dealers tell people there bikes are ready for the scrap yard.
PS.. Welcome to the HDFORUM.
Old Mar 28, 2026 | 02:41 PM
jwcycles's Avatar
jwcycles
Stage III
you want a picture of the throttle sir...not the first cable going to it and by vin its an 07
Old Mar 28, 2026 | 02:46 PM
MURPHCC1's Avatar
MURPHCC1
Harley says the first TBW was 08. Not 07.
Sure, lets see it.
Old Mar 28, 2026 | 02:49 PM
jwcycles's Avatar
jwcycles
Stage III
ok...it did just go bad iguess,,,,its a friends bike thru testing security i did the lay it on the tssm,,,and it starts up and runs well,,,as far aas throttle,,,it is by wire,,not the first cable going to bars,,,and to check parts i pulled vin and it 09/07,,,,,,,,tired of hearing its not throttle by wire
Old Mar 28, 2026 | 02:58 PM
MURPHCC1's Avatar
MURPHCC1
That means it was BUILT in SEPT 2007, making it MOST LIKELY a 08 model year.
My 07 date code is 06/07, June 2006, doesn't make a 06!!
Depends on what the VIN says it is/
10th digit in the vin is model year on the 2001-2009 year models.
And the VIN does NOT show month of build, that date code is on the sticker on the neck with VIN!
Show the pic of the throttle please as you offered.
OH, and one last thing, you MUST know if its a 07 or 08 Model Year as a LOT of parts are not interchangeable between years, MANY improvement in the 08 model year.
rodethedragon
Jul 18, 2010 11:44 AM
bigdogsam
Oct 21, 2009 05:10 PM
Mastif
Aug 31, 2009 03:46 PM
Birdzrk
Oct 17, 2007 07:30 PM
Crunchking
Apr 8, 2007 11:25 PM
