stash13, yous doing same exact thing as mine? I remember auto cancel function was working till I install the brake housing couple days ago. I never seen turn signals light up when I hit brakes though.
I had to bypass my harness control box to make my turn signals to work while brake light is on.Your turn signals do not work as brake lights at that point.
How did you bypass it? I might have to the same thing. I am scared of wires now lol
Thanks that should work, not going through the module...
most likely module is not working properly then
BK rider told me they will send new one but I told them to call midwest and find out the solution before send new one.. so will see
just run your wire from your brake switch on your handlebar controls to the brake light wire on your tailight.
