I ride a 2006 fatboy that recently developed an issue with the left turn signal, sometimes it dont work at all sometimes works normally other times it comes on then starts flashing fast after about 30 secs and then shuts off. I believe it to be only related to the front because i removed the seat and unplugged the rears, no change. I work as an ase automtive tech and i no i can figure this one out if i had a wiring diagram. It seems to be a ground issue but if thats so that means the left and right have different grounds. Anyone know where a man can get a wiring diagram or seen this problem before????
Thanks
Thanks
