Complete Electrical Shutdown...need help
Old May 21, 2014 | 03:20 PM
see22ds's Avatar
see22ds
Default Complete Electrical Shutdown...need help
Hi All, I have a 2001 Wide Glide. Went for a ride Sunday and put maybe 15 miles on the bike, stopped at Walgreens to pick up a few items and went outside fired up the bike and started to leave. Made it about 100 yards and the bike completely died like someone flipped a switch. No electrical power anywhere except at battery.
I have checked the battery, even substituted another, traced every wire I could and inspected. We checked the ignition switch, main breaker, and all connections including grounds...I can not find anything wrong and am at my wits end and about to just drop it off at dealer...can anyone provide any last ditch ideas? Thanks, I appreciate it.
Old May 21, 2014 | 04:14 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Replace the main breaker.
Old May 21, 2014 | 04:18 PM
rooti's Avatar
rooti
Quit usuing your kill switch as a turn signal.
Replace main fuse, check battery cables and connections on both ends. Check kill switch.
Old May 21, 2014 | 05:25 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Kill switch will not cause complete electrical shutdown, but an ignition switch will...
Old May 21, 2014 | 09:37 PM
see22ds's Avatar
see22ds
Replaced main circuit breaker and ignition switch...rechecked ground and positive cables...I don't believe they have any breaks. Still no electrical power anywhere. Switched batteries also...just very frustrating.
Old May 22, 2014 | 04:48 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Check voltage at each post on the main breaker.
Check voltage at each fuse.
Old May 22, 2014 | 07:33 AM
JohnnyC's Avatar
JohnnyC
Wow, Lost both main voltage and secondary.
When that happened on my ride it turned out the main ground lead from the battery to the frame had a broken heavy duty connector and at the frame, the wire was just dangling. I stripped it on the side of the road and re-bolted it to a solid point and rode it home. Later replaced that cable with one from an auto parts store because the original was no longer made.
My though is that you have a main cable that has been flexing and has finally broke in two somewhere inside the insulation of one of the main cables. Using a volt / ohm meter test each battery cable from end to end for continuity.
Best wishes it's something this simple.
Old May 22, 2014 | 04:43 PM
see22ds's Avatar
see22ds
Going to start from scratch tonight...hopefully it is something I over looked.
Thanks guys for the ideas...hopefully later this evening I post good news.
Mike
Tris S
General Topics/Tech Tips
May 15, 2019 11:06 AM
schlawin
Jun 13, 2016 11:20 AM
Joe S.
Sep 9, 2014 11:15 PM
ChicagoBilly
EVO
Jul 7, 2011 11:23 PM
81fxb
Aug 6, 2008 05:16 PM
