Low-Mid Range Cam: SE255, 48h, or TW222?
I know this has been asked a million and one times already. I have pretty much narrowed down the cam choice to these three. Some details on the bike: 2011 RK Classic, 103 engine, stage 1 done (HD heavy breather, V&H monster ovals, Jackpot 2-1-2 headers), and Dynojet PCV with autotune. Mostly do two up riding and rarely get to high rpm and thus 99% of the time I am cruising and thus the three cams chosen above are for the low to mid range torque. Also do a lot of canyon riding, lots of speed and shifting variation but mostly below <50mph.
All else being equal, I know the SE255 (25 intake closing) brings it on at lower rpm than the 48h (29 intake closing), and 48h lower than the 222 (34 intake closing).
Questions:
--255 is the torque king due to the short duration and of course lowest intake closing, is there any concern with long term reliability (valve train) or excessive heat? Has anyone out there experienced any reliability issues with this cam? My bike does have an oil cooler, I run full synthetic (Mobil 1), and can easily adjust the air fuel due to the Autotune (I run at 13.5 AFR, 13.8 at 6th gear cruising).
--255 vs 48h: any significant performance difference? Would there be a felt and noticeable difference in how the bike performs or are they so close in specs it really does not make a difference?
--48h: anyone have this cam with a 103? I found lots of reviews with the 48h but not with the 103. With the 103: Impressions, exhaust sound, valve train sound, etc?
--255: if installed by Harley dealer, is there some f’n EPA process they need to follow that would sacrifice performance?
--IF IF IF IF I were to get some headwork done in the future, what cam is the best choice out of the three? I read somewhere with the 103 engine you want a cam more towards the mid range like the 222, but am not sure here if this is a figment of my imagination or true.
--The bike has about 12k miles, should the lifters be replaced with the cam job? Are the HD SE lifters better than the stock or are stock acceptable with any of these cams?
Any other input would be appreciated, my top choice is likely the 48h just because it falls in the middle of the three and the 255 just concerns me with such an early intake closing and is somewhat at the extreme end of cam specs and I want a little more balance for a low to mid range cam.
Questions:
255 is strong down low, falls off earlier than most, and is a heat producer. A good tune is needed to tame the heat but it is done all the time by good tuners.
48H is a little softer on the bottom end (hole shots) but is an excellent choice for a bagger cam in a 103 with headwork. If you don't plan on headwork, then skip this cam for a stock 103 IMO.
222 is a great choice as well. Comes on strong at the bottom and carries out to the right well. I'm not a fan of Wood cams for my own retarded reasons but dynos tell the story. I've put many in for folks and they love them as well.
Another good low-mid range cam to look at is Steve's cam from GMR Performance, the Genesis 577. Great bolt in cam as well and does even better with head work.
I just went through the whole process you are a couple weeks ago. I finally decided on the 222 and I am not disappointed at all. Comes on early and pulls very hard as far out as I need it. Turned my 103 into a whole new bike. I am very happy. I know after just talking to a local shop here that does a lot of builds that they are recommending the Fueling 575 now for this application. Seems like a lot of lift, but they claim they are using these now instead of the 222 or 48h. Not to confuse you more, just thought I'd toss that out. UltraNutz and ke5rbd have a lot of good advice in this area.
