Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
I was told by a fellow Harley rider that downshifting in order to slow the bike and be in the right gear as you come to a stop is bad and will cause oil to be pushed out of the sump and into the air box. I am new to HD but in every vehicle or motorcycle I've ever owned I've used the motor to aid in breaking. Is this a problem?
Harley riders generally do not even know how to do regular braking. I witnessed once a rider in front of me locking up his rear and crashing because he was cut off. He obviously didn't use front brake at all.
I'd say ride normally, downshift as speed goes down and use engine for braking.
Don't know about the oiling issue, but from what I gather heavy engine braking on a Harley can cause the crank to shift.
__________________________________________________ ____ For ROCKOUT information & purchasing please click the links below...
__________________
NO, they DON'T all do that!
ROCKOUT rocker shaft inserts... make the tapping STOP! From the guy that FOUND and CURED the problem NO ONE ELSE COULD, thank you for your support! Ordering & info http://www.rockout.bizOn ebay! ...CLICK HERE Also on amazon.com...
Does not sound right. The same crank can withstand 80+, possibly over 100 HP. The power of engine braking is nowhere near these numbers. Just another wisdom from wannabe pundits. We have lots of them here.
I don't think they're talking about damage from normal downshifting. More like skipping a gear downshift from 3rd to 1st, where you spin the rear.
