Engine stammer
Old Oct 4, 2016 | 04:35 PM
Jiggles's Avatar
Jiggles
Question Engine stammer
I have an '88 1200 XLH. It's not happy when at a constant speed below 50 sort of like stammering, not bad, just sort of hesitant. Runs well under even a little throttle but coughs a little on shut down. Any ideas of the most likely cause?
TIA
John
Old Oct 5, 2016 | 02:15 AM
Next In Line's Avatar
Next In Line
Sounds like you are shifting too soon and lugging the motor.
Old Oct 5, 2016 | 05:50 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Sounds like it's running a bit lean. Time to tear apart the carb and clean it....
Old Oct 5, 2016 | 01:59 PM
Jiggles's Avatar
Jiggles
I don' think I'm "lugging" it NinL it's not a clean run at higher revs :-(
Not sure if it's running too lean 98 it needs choke to start but doesn't like it left out for more than 5 secs. I did wonder whether it might be too rich? All advice welcome though and I will probably have a better look at the weekend, after all, that's one of the reasons for them :-D
Old Oct 5, 2016 | 04:32 PM
98hotrodfatboy
Yea could be rich, hi float level. Still need to open it up.
Old Oct 6, 2016 | 01:30 PM
Jiggles's Avatar
Jiggles
At the weekend probably 98. What's it like trying to get carb kits, you know, with new needle, seat, gaskets etc.?
John
Old Oct 6, 2016 | 07:38 PM
Ed Ramberger's Avatar
Ed Ramberger
Is it worse cold or hot? If you're thinking fuel, if cold it's lean, if hot it's rich. Pull out the enricher just slightly and see if it gets better or worse.
Old Oct 7, 2016 | 05:54 AM
98hotrodfatboy
Ebay or your best bet a local Indy. Get the intake to the head seals as well. Known to go bad.... pt#27002-89
Old Oct 7, 2016 | 12:28 PM
Jiggles's Avatar
Jiggles
It's worse cold Ed, but it's still there when hot :-( It's not a bad "stammer" it's more annoying and worrying on close in maneuvering :-o
Thanks 98, useful to know!
John
Old Oct 7, 2016 | 03:00 PM
Gozzie's Avatar
Gozzie
If the bike came from a different part of the country such as Denver or other high altitudes vs Louisiana at sea level your jets will definitely be out of whack somewhat
