107 Winter upgrade anything I'm forgetting?
Old Nov 1, 2016 | 09:23 PM
ReapersWG's Avatar
ReapersWG
Default 107 Winter upgrade anything I'm forgetting?
So decided to finally go to 107. He's what I have for parts not sure if I'm forgetting anything
107 Mahle pistons with 15cc dome matched to brand new takeoff harley cylinders.
S&S rollers rockers and premium lifters
Tman 590 cams CR will be set at 10.8
Rest of my present parts are D&D fatcat with big bore baffle. SE Heavy breather SE 58mm tb and SE 110 plus heads with Big Boyz headwork. These heads are different from regular CVO heads. All new cam bearings and gaskets also. Hoping to be in the 115 area when tuned.
Also will be tuned by Bean at Big Boyz with a SERT this spring. My current 103 ran 107 and 109 when Bean tuned it. Anything else I should consider? Thanks
Old Nov 2, 2016 | 08:28 PM
djl's Avatar
djl
Are you sure about that 15cc piston dome?
Old Nov 2, 2016 | 09:08 PM
Max Headflow's Avatar
Max Headflow
Didn't know 110 heads CCed out at 102ccs.
Old Nov 3, 2016 | 01:47 AM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
Yes, you should consider what you're talking about before posting!
Old Nov 3, 2016 | 09:49 AM
Max Headflow
If this is addressed at me, just trying to figure out what the CCs are.. You are not allowed to ask questions here?
Old Nov 3, 2016 | 01:58 PM
OldEnuf2NoBtr
Wasn't directed at you.
Old Nov 3, 2016 | 07:35 PM
jack6hd's Avatar
jack6hd
How about a clutch upgrade?
Old Nov 4, 2016 | 09:05 PM
ReapersWG's Avatar
ReapersWG
Heads are 95cc and with a 40 thousandths head gasket the cr will be around 10.8. And not sure what I need to consider before I talk or ask for advice. Thinking I'll need a clutch upgrade and I'm open to suggestions.
Old Nov 5, 2016 | 04:15 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
VPC clutch lock-up hat with a S/E or Barnett spring.
Scott
Old Nov 5, 2016 | 07:22 AM
prodrag1320's Avatar
prodrag1320
with decent headwork,the rest of the parts your using should do 120+/125".ide go with a bandit sportsmen
