Stock 103 (88,96) valve spring lift maximum?
Received 2,189 Likes
- SE HP valve springs 18013-0A .590 lift
- S&S bee hive 106-5909 .650 lift
Yeah, .650 lift will put more stress on the valve train and roller rockers should be installed. Most "street" builds don't need .650" lift cams; requires attention to detail to avoid piston to valve and valve to valve clearance issues.
7mm,beehive heads can go to .600" with stock springs,but there is a lot more to look at,for one is seat pressure.make sure it match`s what the cam calls for.second is valve to valve & valve to piston contact,this must be checked on all cam installs with more than .180 TDC lift and on all installs where bigger valves are being used,and third,make sure your compression,CID & rest of build even warrants a bigger cam.your build should be a group of parts that compliment each other,not fight against each other.we get a lot of calls to "fix" builds done by fly by night,"high performance" shops who feel bigger is better and end up with a **** running bike & way less HP/TQ than before the work was done
if i'm not happy with my basic kit, i may ebay and send you some heads. Rob seemed pretty happy with your stage II work a few months back.
late beehive heads will easily handle 585 cams,but I would really think twice about your build with bone stock heads,saying your leaving some on the table is a understatement.heads should have at least 1.900/1630 valves if not 1.980 intakes.you could use the S&S 79cc heads,but youde have to machine the combustion chambers to releave compression,it would be WAY too high for the 585`s
