Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
I found this on another forum, I just don't understand the 2-5/16" measurement. Is it from the spark plug?
What I do is:
Measure in between the head bolt(short one on the intake side},and the spark plug hole 2 5/16" from the outer fin.
Center punch the spot.
Set the head up on an angle plate set at 15 degrees.
Use a wiggler or other method to keep the quill on the center punch mark.
Spot face with a 3/4" center cutting end mill.
Chuck up a 11/32" drill,and drill down 3/4".
Chuck up a .090" drill,and drill down through the chamber.
Set up a 10mm. tap,cut threads,and you're done.
