Adjusting quench
Old Jul 25, 2017 | 10:53 PM
canyoncritter's Avatar
canyoncritter
Default Adjusting quench
Excuse my ramblings it comes out that way,just checking my thoughts over here.
.045 head gasket, 4 pisces of solder, .060 rolled motor threw, solder measured .050 .050 quench ouch. My head tells me that means I have .005 deck height...
If I throw a .030 head gasket, that should bring me down to a .035 quench ,
030+.005 deck = .035
Would it be worth it to take .005 off the bases of the jugs, for a .030 quench?
Old Jul 26, 2017 | 03:02 AM
fidel's Avatar
fidel
put a .027 end at 32
Old Jul 26, 2017 | 03:48 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
The closer you can put the piston to the head, w/o contact during full operating temps, the less chance of detonation, and more chamber turbulence.
.030" keeps things in the safe zone.
Scott
Old Jul 26, 2017 | 04:45 AM
canyoncritter
Scott am I doing my math right so far? Ie need to take .005 off the bottom of the barrels, bring to .030 squish. Or is there a head gasket I can use to bring it down,or not a great ideal.
Not to be stupid question of the day, explain the day, can you explain the operating temp , and 30s the safe spot.
Old Jul 26, 2017 | 05:27 AM
Schex's Avatar
Schex
"safe zone", has enough room for no piston to head contact when the carbon layer forms on both,
and tight enough to promote turbulence, more complete combustion, and help combat pinging.
At operating temp, dimensions change due to heat expansion.
You'll be OK at .035"
northeastconfederate
Exhaust System Topics
14
Jul 14, 2011 06:54 AM
voodoodrug
Jul 8, 2010 10:27 AM
largeswine
Mar 26, 2009 09:26 PM
iknowyoueazyryder
Ironhead
Feb 18, 2008 05:25 PM
jakazz
Jul 2, 2007 10:05 AM
