88 Dual Cam not turning over
Old Jul 12, 2017 | 09:17 AM
astarks82@gmail.com's Avatar
astarks82@gmail.com
2nd Gear
Default 88 Dual Cam not turning over
Hi guys. First time poster here. I just recently inherited my father's 01 Springer Softail with the 88 Dual Cam engine. It sat for over a year without being started. Got new plugs and I gave her an oil change and when I drained the oil tank, virtually nothing came out (not even enough to wet the whole bottom of the drain pan). I didn't think much of it and continued. (I read later that over time the oil can drain into the crankcase) When I tried to start her, she was having trouble turning all the way over. I thought maybe it was because the top end was dry and there was quite a bit of resistance from friction. So I shot a little oil in the plug hole just to wet her lips. While I had the plugs out I decided to do a spark test. Pulled both plugs out of the cylinders and stuck them in the caps. Hit the starter and bam! She's turning over just fine and I got a good even spark. But when I put the plugs back in and try to turn her over it's the same thing again. Seems like she's got too much compression or something. I guess my question is, can having too much oil cause it to turn over too slow? Idk where to go from here. My only idea is to drain the tank, pull the plugs, and hit the starter to try and pump oil out of the crankcase. Thanks in advance.
Old Jul 12, 2017 | 10:01 AM
Brian Kelley's Avatar
Brian Kelley
  • change the engine oil and filter
  • change the plugs and gap them
  • measure the resistance on plug wires with ohmeter; likely replace the set
  • charge battery fully with 1-2amp trickle charger; or replace it
  • is it carb? spray gumout carb cleaner liberally in its throttle body; add carb cleaner to fresh gas and fill tank
Sounds like it could be a fueling problem (carb or efi), because you say you have spark and the starter is turning the crank over 'just fine'. But start with the above. Just have to coax it with little changes. It's the same thing as a neglected lawnmower or chainsaw at this point.
Old Jul 12, 2017 | 10:34 AM
astarks82@gmail.com
2nd Gear
But I'm not sure why it's not turning over fast enough when the plugs are in, but when I turn it over with the plugs out, it turns over just fine. It's carbed by the way. Haven't really checked it out yet. That was my next project. I just need to figure out why she's not even trying when the plugs are in.
Last edited by astarks82@gmail.com; Jul 12, 2017 at 10:35 AM. Reason: Too many quotes
Old Jul 12, 2017 | 12:03 PM
98hotrodfatboy's Avatar
98hotrodfatboy
Look around for compression releases. Sound like the motor has good comp or the battery could be low. Put a volt meter across the battery terminals and see what you get when cranking it over shouldn't drop below 11.0v with a good battery... May have to put a good charge on it....
Old Jul 12, 2017 | 12:23 PM
Lunchboxx's Avatar
Lunchboxx
Sounds like a battery or weak starter issue to me.
Old Jul 12, 2017 | 12:39 PM
rigidthumper's Avatar
rigidthumper
All the oil that was in tank, drained into the crank case over time. Battery has to overcome compression and 3 quarts of 20w50 under the pistons. Drain the fresh (recently changed) oil into a clean container. Put the plug back in. Pull the spark plugs out, and with a new battery hooked to a tender, crank the engine over in 20 second bursts with a minute between cycles. repeat this a dozen times, watching the oil level in the tank, until you need to drain the oil tank into a different container or the level stops rising. All the previous oil will return to the bag. once all that is done, drain the tank, and put two quarts of the fresh oil from the clean container back into the oil bag.
Once this is done, and the bike is turning over properly, if it still doesn't start, we'll walk you through that, then. If it starts, warm it up, and set the oil level.
HTH
Old Jul 12, 2017 | 01:22 PM
astarks82@gmail.com
2nd Gear
HTH
Thanks! I'll give that a try when I get home from work and let you know. And so everyone knows, I'm not using a battery to start. I'm jumping off my F-250 Super Duty. So I'm definitely getting enough crank amps. The battery is shot. It's not even hooked up. Gonna get a new one when I'm ready. And there's plenty of spark when the plugs are out. They probably aren't sparking when seated because the engine isn't turning over fast enough to make a charge. So the full crankcase seems like the most logical issue.
Old Jul 12, 2017 | 02:04 PM
djl's Avatar
djl
Not to disagree with rigidthumper, his approach in post #6 will work but slow and tedious. I would remove the crank case plug located on the right (brake) side of the crank case and let all the oil in the sump drain out. The plug is a pipe plug and will require a hex (think allen wrench) to remove. It should come out easily but if you feel hard resistance, revert to rigidthumper's approach. Once all the oil has drained from the sump, put some pipe sealant on the plug threads and reinstall the plug. Go easy on the reinstall, there is no torque spec but it pipe plugs are tapered and if you crank down on tightening the plug you could crack the case. Just snug it up and give another 1/4 turn. Refill the oil tank and try starting then.
If the bike is carbed, you might very likely need to remove the carb, disassemble, clean and blow out all orifices and passages before it will start and run properly.
Old Jul 12, 2017 | 03:53 PM
astarks82@gmail.com
2nd Gear
I couldn't get the crankcase set screw out so I went with the hard way. Plenty of oil came out this time. Only problem was the new had already mixed with the old so it's no good now. I did pour some back in just for starting purposes and tried. No luck. Same thing. Turns over just fine with the plugs out. But with them in nothing. Just the starter cranking and not turning over.
Old Jul 12, 2017 | 09:55 PM
rigidthumper
The jumper cables are transferring enough voltage, but maybe not adequate current. You might try it with a good HD battery properly installed, cables on the terminals so proper current flow is established.
