Head work?
Old Oct 11, 2017 | 07:21 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
Cylinder head re-surdace is a great way to increase the compression, but the amount needed to be removed, in the case of an 88" with a 37 cam is beyond, as many things come into play, ie , manifold fitment(or re-surface the intake mounting surfaces), pushrod clips, geometry, etc,.
Scott
Old Oct 13, 2017 | 09:03 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Wink
As Scott indicated to utilize the 37's with head work you will need that comp bump... The most effective build at this point would be the 98" package. I would think only another $600 for the Pistons and bore if you do the toolling... I converted my 80"er to a 96"er and the power band is unbelievable... 115/109...... = FUN...... That was with head work as well....
Old Oct 13, 2017 | 08:55 PM
Max Headflow's Avatar
Max Headflow
And you did that with a set of 37s and Scott's heads? Impressive..
Old Oct 14, 2017 | 06:03 AM
98hotrodfatboy
No, of course not Max... Just an indication of what good head work will accomplish... MAXHEADFLOW........ ISN'T THAT WHAT IS BEING CONSIDERED HERE?
Old Oct 14, 2017 | 09:26 AM
Max Headflow
Sorry, It read like you used the 37s.
Lundee
Exhaust System Topics
Jul 19, 2011 06:59 PM
Bob'n'Stang
Jul 17, 2010 05:42 PM
otaramc
Nov 13, 2008 10:42 PM
harleymark
Sep 5, 2007 04:05 PM
05 Wd Gld
May 4, 2007 09:16 PM
