Head work?
Old Oct 3, 2017 | 10:34 PM
REW13's Avatar
REW13
Default Head work?
On an 01 fxdl, would it benefit hp gain from a port and polish? Not really wanting to a full build or go big. Just want a little more from the motor.
Thanks
Old Oct 4, 2017 | 06:07 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
I'll help nicely, and the install of a set of Andrews 21 cams will make a nice combo.
Scott
Old Oct 4, 2017 | 07:06 AM
prodrag1320's Avatar
prodrag1320
air flow is the key to making any kind of power,just make sure the headwork compliments the rest of your build
Old Oct 5, 2017 | 04:59 PM
REW13's Avatar
REW13
Already have andrews 37 cams, gears and re worked carb, with v&h straight shot pipes, so a wee bit of work is what I'm looking at doing
Thanks
Old Oct 6, 2017 | 05:32 AM
Hillsidecycle.com
Sponsor
Those Andrews 37's optimze at 9.8-10.0 compression.
That said, mighty tough to get there without a domed piston, in an 88", and i do not believe those are offered anymore.
Scott
Old Oct 6, 2017 | 08:27 AM
djl's Avatar
djl
CP/Carrillo offers several domed pistons for the 88" motor; 8.6cc, 9.3cc and 9.9cc. I would think the 9.9cc would be perfect with the 37 cams and a .030" head gasket. Static would be about 9.9 and CCP about 190; should be a runner for an 88" motor. You might find that you will need a programmable ignition to work the timing.
Old Oct 6, 2017 | 10:35 AM
Hillsidecycle.com
Sponsor
And in the whole picture, if pistons are to be utilized, then may juat as well bore to say 98", for very short money.
Good info on the 88" pistons djl, thought that a 3.750" bore T/C piston was lost in the weeds.....guess not.
Scott
Old Oct 6, 2017 | 11:19 AM
djl's Avatar
djl
Originally Posted by Hillsidecycle.com
And in the whole picture, if pistons are to be utilized, then may juat as well bore to say 98", for very short money. Good info on the 88" pistons djl, thought that a 3.750" bore T/C piston was lost in the weeds.....guess not.Scott
Only reason I know is that I recently bought a set of CPs for a 98" motor and saw the TC88 pistons in the catalog; otherwise I would not have known either. Having said that, I could have stuck my foot in mouth (not the first time) as I have not checked availability but it was their 2017 catalog.:icon_wink
Old Oct 10, 2017 | 05:58 PM
TontoTonto's Avatar
TontoTonto
DJL is correct, Carillo does offer a dome slug for for the TC88. Like him I am alos running a dome in my 98. 6cc's to be exact.
Old Oct 10, 2017 | 07:21 PM
REW13's Avatar
REW13
Instead of using dome pistons? Could you just shave the head a little?
Like a car to increase compression.
