Fresh 107 on bench. Hissing out intake valves
An easier alternative to a leak down test, is a vacuum test.
Most machine shops that do head work will have a vacuum tester.
All 3 of my Buddies that have automotive machine shops have vacuum testers.
No cylinder head leaves the shop without being Vac tested on every port.
You should never be able to hear air escaping past the valves when turning an engine over by hand.
