What is the best S&S cam for 107 kit?
I would like to know what the best S&S cams would be for a 107 kit with 10:1 compression ratio and for a 10.25:1 ?
My bike is a stock 2008 ultra with a high flow air cleaner and a pro pipe and a 30 tooth trans pulley. I also have a TTS tuner . I'm not looking for a high performance build but would like to freshen up the motor and at the same time get better performance out of it. I want to go with S&S cams for the easy start feature even though there are a lot of other good cams available. I'm going to use S&S lifters , pushrods and cam chain tensioners. I'm not going to be doing anything with the heads at this time but will be in the future. I've read the forum and think that a 570 for the 10:1 might be the best choice but am unsure about a cam for the 10.25:1 . My priority is reliability as well as a good performer.
The S&S .570 will be right at home at 10-10.2 cr, but a an Andrews 57, or a Wood 6, will have a more aggressive delivery, same compression.
Just a thought.
Scott
Just a thought.
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
