Cam question for 05 roadking.
Old Feb 28, 2010 | 08:52 AM
jurgie's Avatar
jurgie
Default Cam question for 05 roadking.
I have two different packages that i was presented with and i would like some feed back on which one would do the best for this 88 ci fuel inj. motor.Ive been reading on this site ,cams,dyno numbers,got some info but still looking for some. I plan on just doing the cams now and doing some headwork later so do i have consider this when sizing cams. these guys are telling me iam good to go now and to do future head work.
These are the two
install kit99-06 gear dr 33.99
pc usb har touring 02-06 305.00
quick install push rods kit 124.91
4-gear cam dr set 382.67
gear drive andrews tw26 cam 273.66
6 hours labor 372.00
tot 1575.00
number2
mackey 510 gear drive cam 329.00
419kh s@s geardrive kit 373.00
17997-17a push rods 139.99
inner cam bearing 23.00
outter cam bearing 33.98
se race tuner 459.00
dyno 266.00
4 hours labor 288.00
tot 1904.00
Old Feb 28, 2010 | 09:03 AM
Road Ranger's Avatar
Road Ranger
I went with the S&S 510 gear driven cam, Haven't gotten mine back from my indy yet but either of the 2 cams you have chosen are good, and with the right tuner (TECH) those cams are good to go if you upgrade to a higher displacement (95") and headwork but I would say anything bigger than that would require a beefier cam.
Old Feb 28, 2010 | 09:18 AM
xxxflhrci's Avatar
xxxflhrci
26G's work for me. 535 bucks for a complete cam kit, 120 bucks for SE pushrods, 50 bucks for Crane #10530 lifters for a SBC and 99 bucks for a DFO to tune it myself.
Old Mar 1, 2010 | 12:03 AM
Dailydbl's Avatar
Dailydbl
I've got the 26g and have been very happy with it. Comes on early and holds plenty strong through the rpm range I need in a bagger. It's a good cam for an otherwise stock engine and still works well with a mild BB bagger build - see my current build below.
Monte
Old Mar 1, 2010 | 07:21 AM
jurgie's Avatar
jurgie
thanks guys,I JUST DIDNT WANT THAT LOBING EFFECT INTHE LOW GEARS IN CITY TRAFFIC IF YOU KNOW WHAT I MEAN.thats why i thought by coming on at 1800 rpm ii should know what gear to be in .
thanks jeff
Old Mar 1, 2010 | 07:31 AM
dawg's Avatar
dawg
Just out of my personal preferences, I'd make some changes to either that you went with. First, I'd go with the newer SE pushrods instead of the older ones if you insist on changing rods, but I wouldn't bother changing the rods. Second, I'd go with the TTS Mastertune. Again, that's my preference.
Old Mar 1, 2010 | 08:00 AM
Heathen's Avatar
Heathen
The Mackie 510 is a great bolt in cam,Like Dawg said ,save some money and keep your push rods. When your ready for heads ,check Mackie also his heads /headwork is awesome.
Old Mar 1, 2010 | 08:37 AM
El Rey's Avatar
El Rey
Why do so many people go with the andrew's 26? Why not the lower numbers?
Secondly, don't you have to have good crank run out to do gear drive as opposed to chain drive?
I'd like to do Andrew's chain drive with cams.
Old Mar 1, 2010 | 09:03 AM
rkrdr2's Avatar
rkrdr2
Crank run out can not be more than .003" for gear drives...Rule of thumb is...only about 1 in a 100 will exceed the .003"...Andrews 21/26,S&S510,SE203s,woods tw6 I don't think you will be disappointed in any of these cams as a cam only upgrade in 88in motor.
Old Mar 1, 2010 | 09:35 AM
mongomark's Avatar
mongomark
Rather than the PCIII usb, I'd go with the PCV retro. Same cost and down the road you can add autotune if you want.
WideGlideFever
May 4, 2015 12:20 PM
Jackpoticorn
Sep 17, 2014 12:17 PM
JoshuaCannon
Jul 24, 2010 09:11 PM
TBone
Apr 15, 2007 02:37 PM
HTRAUD
Dec 11, 2006 10:06 PM
