Adding compression
Old Nov 28, 2017 | 09:27 AM
Clayton24's Avatar
Clayton24
Default Adding compression
Will adding compression on a 103 with 57 h cams help low end torque? Thanks for all replies ?i should be at about 9.8 or 9.9:1 rite now thinking about 10.2:1 ? Thanks for all info greatley appreciated!
Old Nov 28, 2017 | 10:54 AM
hrdtail78's Avatar
hrdtail78
10.2 will help through out entire RPM range and is a needed for the 57. IMO it is kind of a dud at stock compression.
Old Nov 28, 2017 | 11:33 AM
98hotrodfatboy's Avatar
98hotrodfatboy
10.2 would be the limit on that 38* ivc.... Depending on your elevation...
Old Nov 28, 2017 | 05:20 PM
Clayton24's Avatar
Clayton24
maybe thats what im missing it runs great mid an top end its pretty soft below 3000 rpms ?
Old Nov 28, 2017 | 07:35 PM
pingman68's Avatar
pingman68
You ain’t got enough straight away out on Lick Creek road to get to any top end.
Old Nov 28, 2017 | 10:24 PM
Clayton24's Avatar
Clayton24
not at all lol!
Old Nov 29, 2017 | 05:43 AM
pingman68's Avatar
pingman68
not at all lol!
Been a few years since I been back up that way, but I grew up around there in the Tri-State area.
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
10.2 is where we set those here.
Scott
Old Nov 29, 2017 | 06:39 AM
Clayton24's Avatar
Clayton24
your prob not missin much where at in the tristate was you from ?
Old Nov 29, 2017 | 06:40 AM
Clayton24's Avatar
Clayton24
Scott
im gonna try that an see how it wrks out thanks !
