Piece of rag in crank case
I have a 07 road king classic I just bought and have only rode 1 time...recently pulled out the crankshaft sensor to replace it while I was waiting on the new one to arrive I temporarily put a small piece of cotton tag approx 3”x3” in the crank shaft sensor hole to keep drt out unfortunately I forgot the rag was in there and went to start the bike after replacing grips and wanted to check to make sure the throttle was correct. I cranked the bike 2-3 times for 2-3 seconds max with the sensor out and bye bye rag sucked it right in with the flywheel... what should I do I’ve of course drained the oil pulled the filter even pullled the DO NOT TOUCH sump drain...I’ve filled the sump with oil through the crank sensor hole turned the engine over by hand the only place I’m getting reminents are out of the sump hole nothing big just really small pieces I’ve tried air compressor everything I can think...how far could that rag go without starting and losing compression out of the crank sensor hole??? Definitely has not made it to the pan or back to the filter no signs there. Where would it go next from the crank case? Will the engine shred it and filter it out or will it cost me a motor. I was thinking pulling the jugs or pulling the cam chest getting to the oil pump.any suggestions? What should I do .. any help would be greatly appreciated. And yes I know I’m an idiot so please don’t remind me... would greatly appreciate any help on what to do. Weather is breaking and it’s time to ride. Won’t be riding till next year if I have to split the cases or buy a motor ..thanks
So you're running two threads on this hoping for different answers than the first one? There's already three pages on your first post here:
https://www.hdforums.com/forum/touri...e-problem.html
This is not a good plan. Like I stated in his other thread on the same subject - at a minimum he needs to take the top end off. If a rag was pulled in through the crank hole, it was by the reluctor teeth. He needs to stop turning it over & filling it with fluids and take the top end off.
mr. ed is mucho spot on!!! pull the easiest jug set.
natural engine operation will try and force the rag towards the scavenge oil pump BUT: it can get chewed up and find it way into splash lube bearing point, not so good!
true story:
we put in a generator set with a straight 8 waukesha natural gas engine, the other crew set the O2 wrong and crisp the engine. waukesha crew came out and overhauled it under warranty but someone left a rag in it. the rag plugged the oil pump and crisped another engine, waukesha ate it and overhauled it again.
another time, on a tender drilling platform, a mechanic left a 9/16 open/box inside the generator, cranked it up and it threw the prettiest blue flames and molten copper you could imagine.
closer to home, father took delivery of a new tractor. he got on it to drive it to the barn and it broke into two pieces, some knucklehead left a wrench inside the tranny.
NEVER HOPE FOR THE BEST
when it is in the power of your hands to fix it right.
true story:
Yeah I’ve started tearing the bike down got the exhaust off tank seat basics so far I have a new cam cover so I went ahead and pulled it off just for shzz and giggles. I’m thinking when it’s all said and done I’m going to want to and maybe end up pulling the pump making sure it’s clean while I have the heads off it won’t hurt to pull the cans. Replace my tensioner while I’m at it. Like you said do it right. It’s the only way .. If I so happen to pull the front jug and I find it down in there I have a whole Top and gasket kit should I pull the second jog and replace the gaskets or is it one of those if it’s not broke don’t fix it things?
