Maxi Pads and Galled Pistons
#31
A lot of good suggestions. When I have a cylinder running hotter than the rest on my drag racing air cooled VW, the first thing I look for is a plugged injector, (this is mechanical injection ala Hilborn, so plugged injectors are much easier to see than electronic injectors). It runs on methanol, and when a hole goes lean, it gets ugly in a hurry.
After that, I'll look for vacuum leaks causing a lean condition. My VW is turbo'd tho and vacuum leaks are rarely an issue, but when it was normally aspirated, it was fairly common. These motors shake as bad as a Harley, so thing work loose, crack, etc.
If it was on my bike, I'd be looking at vacuum leaks, fuel delivery, blocked cooling air.
#32
Am ordering a fuel tank crossover line quick disconnect and when that arrives I'll be doing compression test, leak-down test, injector swap front-to rear, vacuum leak test, MAP sensor, IAC, TPS, air temp sensor, and baro sensor test just to eliminate the things within my control. I'll also be installing a data logging system incl wide band o2 sensors and dual gauge *if* I the system is capable of logging TP in addition to AFR and RPM. If I cant find a system capable of that, then I'll just bite the bullet and buy a thundermax.
#33
This is the one I was thinking of getting, does what you want.
https://www.rbracing-rsr.com/lsr21.htm#o2port
Look under o2 port tab
#34
Received 5,388 Likes
#35
Already been down the dyno tune route.
04ctd
22
08-15-2019 10:25 AM
HDDyna2006
Exhaust System Topics
05-26-2008 11:40 PM
