HD not supplying SE cam tools in UK
Old Nov 29, 2018 | 03:40 AM
rpl63fxdf's Avatar
rpl63fxdf
2nd Gear
Unhappy HD not supplying SE cam tools in UK
Hi all. Chester HD in the UK have informed me that HD are no longer supplying the Screamin Eagle Cam tools. (94107-09A, 94078-09, 93979-10, 94144-09). I just bought the SE255 cams and all the installation stuff, but can't order the tools !! Doh !!!
Anyone else heard anything? Any other UK sources?
Thanks
Old Nov 29, 2018 | 04:59 AM
Tired's Avatar
Tired
Those bastards!
In any case, I've changed a lot of cams on twinkies and never owned any of those tools.
Old Nov 29, 2018 | 05:34 AM
rpl63fxdf's Avatar
rpl63fxdf
2nd Gear
Unhappy
Thanks Tired - another dealer just informed me that HD may discontinue the tools in the new year! Guess I need to search for help on changing cams without them.
Old Nov 29, 2018 | 05:44 AM
prodrag1320's Avatar
prodrag1320
you can get the tools you need from JIMS,they made them for HD
Old Nov 29, 2018 | 05:50 AM
rpl63fxdf's Avatar
rpl63fxdf
2nd Gear
Thanks - JIMS tools seem to cost a lot more in the UK - but might just have to bite the bullet (I'm not too expert at workarounds......)
https://www.harleycustom.co.uk/produ...rm384879/39865
https://www.harleycustom.co.uk/produ...rm512879/39866
Old Nov 29, 2018 | 07:15 AM
ROCKOUT Rocker Products
Sponsor
Get them on ebay.... Heartland tools.
For ROCKOUT information & purchasing please click HERE For all Twin Cams and Evo Big Twins & Sportsters
__________________
NO, they DON'T all do that!
Also on amazon.com...
Old Nov 29, 2018 | 08:21 AM
djl's Avatar
djl
Or George's Garage. However, I also have installed cams without those tools.
Old Nov 29, 2018 | 09:41 AM
LQQK_OUT's Avatar
LQQK_OUT
A previously mentioned, two sources for HD specific tools are:
Georges Garage
Heartland Tools
The interesting thing I noticed is that starting in 2018, the HD Screamin' Eagle catalog stopped listing the specialty tools they previously offered.
Old Nov 29, 2018 | 09:42 AM
Zanthamos's Avatar
Zanthamos
I typically use a brass drift and 2 pieces of 4x4 blocks to support the cam plate, brass drift the cam out of the plate and same back in. The tool is not truely necessary just makes it easier if you have a press.
Old Nov 29, 2018 | 09:59 AM
grbrown's Avatar
grbrown
Wink
Thanks
Hello old chap, from darn sarf. As the replies above indicate, being a Harley owner is helped by being resourceful! I'm sure you can find a useful on-line video, even a thread somewhere around HDF, with helpful tips to avoid needing those tools. You were going to be paying 'Harley tax' whether you used a dealer or brought them in yourself, so see if you can save yourself that extra cost. I would point out that the genuine FSM is essential, if you don't have one, now that IS worth buying!
