Advice on do it yourself Evo top end rebuild?
Old Dec 8, 2018 | 08:47 AM
JDixon's Avatar
JDixon
Default Advice on do it yourself Evo top end rebuild?
Hello Everyone,
I have a 1998 Evo Wide glide with 130k miles that needs a top end rebuild. I'm planning on attempting myself and am looking for advice. I have a manual. I have replacement Axtell cylendars with preinstalled pistons. ..85CI. the heads i'll send out for whatever rebuild it needs. I would also like to check out the cam condition. It's got an Andrews EV27 with Screamin Eagle adjustable pushrods. Screamin Eagle slip on mufflers. I'm an HVAC Mechanic so I'm not unfamiliar with tools etc. My question is tips getting it apart/back together with timing set up correctly and pushrods adjusted correctly etc.
Any suggestions appreciated
Old Dec 10, 2018 | 07:10 PM
jurgie's Avatar
jurgie
GET AN OWNERS MANUAL AND GET IT DONE. It will tell you all the things you need to know.There not hard to work on if you can wrench.
Old Dec 11, 2018 | 05:52 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
Some mild cylinder head work(our Stage I) and set the compression at 9.8, 9.9 cr for that EV-27, will complete that combo.
Inspect the lifters for loose rollers, as HD issued a bulletin to do so at 25,000.
If in question whatsoever, replace with a set of S&S lifters.
Inner cam bearing inspection/replacement at this time would also be wise.
Scott
Old Dec 11, 2018 | 06:15 AM
Architect's Avatar
Architect
Check the lifters, if stock just change them. I would go back to the stock fixed push rods. Everything is apart, they just drop in from the top and one less thing to mess with, my opinion others will vary.
Old Dec 14, 2018 | 05:42 AM
Hillsidecycle.com
Sponsor
An Andrews 27 cam has an aggressive lobe profile.
That said, an adjustable pushrod is a darn good idea.
Scott
Old Dec 14, 2018 | 07:43 AM
RANGER73's Avatar
RANGER73
The biggest PITA is the tools you'll need to buy that you'll never use again. And buying ALL the parts you MIGHT
need incase they're worn and you weren't expecting to change but you might need once you get in there, so you're not
into the job then discover you need them and don't have them and now need to order them and wait for them to arrive.
Don't ask me how I know.
Ya, OCD
Old Dec 15, 2018 | 01:19 AM
JDixon's Avatar
JDixon
Thanks all for the advice. I have the winter months to sort it out.
Old Dec 18, 2018 | 08:16 AM
LQQK_OUT's Avatar
LQQK_OUT
Why would an aggressive lobe profile make any difference in regards to using an adjustable versus a non-adjustable pushrod?
Old Dec 18, 2018 | 09:58 AM
Hillsidecycle.com
Sponsor
The use of aggressive lobe cams over the last 25+ years, has taught us to load the lifter to .140"-.150" on a .200" travel plunger, via an adjustable pushrod, to help with quiet engine operation at full thermal expansion.
OEM fixed units do not allow that precision adjustment.
Scott
JDixon
EVO
35
Dec 10, 2018 05:56 AM
Ken97fxstc
Engine Mechanical Topics
Jun 15, 2017 06:02 AM
waynemags
EVO
May 22, 2009 02:52 PM
1931jamesw
Exhaust System Topics
Dec 10, 2008 12:32 PM
ssls6
EVO
May 8, 2007 05:24 PM
