Houston we have a problem......Lifter failure
Luv2Jugz (02-14-2019)
Thanks guys....I live about an hour from Hillside and some friends have had Scott do work on their bikes, so gonna load it up and stop out there and see what he can do. It will probably end up bigger, as I need to get higher compression piston anyways. I think the scores are too deep to use the Jims reamer, was hoping someone had used them and could shed some light.
$150 is a steal. I worked in a machine shop environment 46 years and have a small shop. It would take me 3 hours to sleeve it since I would need to make sleeve.
Would not even think about trying to clean up the bore except by boring. That missing material would probably pull a reamer or cause it to cut funny.
Just so you know, cases are running $1400 plus at least $600 to swap the crank over plus gaskets.......
Luv2Jugz (02-15-2019)
