Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
After runnin for a quick ride the bike starts to puff white smoke, I hit the throttle it goes away for a second but comes back. Recent engine work done includes, valve guides, new seals, heads cleaned, all gaskets changed, woods 555 cams installed with new bearings and lifters with adjustable rods. I also threw out the fuel pak for a power vision with a loaded tune from fuel moto.
Could it it be the tune or cold weather causing the white smoke out the exhaust? It was 43 degrees and it hasn’t been warm here in Nevada. I’ll see if I can post the video
We alert our customers to use conventional petroleum oil for the first 1000 miles, as we do the same in our own bikes, and the shop mule bike also.
Scott
