white smoke?
Old Mar 29, 2009 | 05:53 PM
cookieman's Avatar
cookieman
Stage I
Default white smoke?
having a "brainfart" is it white smoke is ok and black smoke is not good? can't remember
Old Mar 29, 2009 | 05:59 PM
Harleyriding77's Avatar
Harleyriding77
white could be condensation being blown out, black is usually a rich gas mixture, and the blue/gray smoke is burning oil
Old Mar 29, 2009 | 06:00 PM
WildBill2566's Avatar
WildBill2566
White smoke = water, (head gasket etc)
Blue smoke = oil (rings, valve seals etc)
Black smoke = fuel (injectors etc)
If its white smoke from an air cooled motor, its likely to be just clearing the condensation from inside the exhaust, and should dissappear after a few minutes.
Old Mar 29, 2009 | 06:27 PM
1flhtk4me's Avatar
1flhtk4me
If its white smoke from an air cooled motor, its likely to be just clearing the condensation from inside the exhaust, and should disappear after a few minutes.
And if it's water cooled,go to #1.
Oil could also look like white and will not disappear quickly.
Old Mar 29, 2009 | 07:37 PM
bigskyhd's Avatar
bigskyhd
If it's white and it continues after heated up to operating temperature, you've got some kind of leak allowing moisture to get into the engine, and/or exhaust. If it goes away after warming it up to temp and riding a while, probably just had some condensation buildup inside from your previous ride. Did you maybe just go for a short haul on your last ride before you noticed this? Engine may not have come up to temp, and the condensation was trapped until you ran it this time. Just a thought.
Old Mar 29, 2009 | 07:42 PM
nocarb's Avatar
nocarb
Wouldn't want either one.
Old Mar 29, 2009 | 08:03 PM
wolfshead1's Avatar
wolfshead1
For some reason I believ that a little white smoke is the sign of a tuned motor.It is actually trying burning the fillers in the fuel.
Old Mar 29, 2009 | 08:13 PM
StreetGlideMedic's Avatar
StreetGlideMedic
Did you notice this on start up? Or after you've been riding for ahile? or all throught your ride! Easier to figure from there!
Ride safe, Mike
Old Mar 29, 2009 | 11:25 PM
bigskyhd's Avatar
bigskyhd
Hey Wolfshead, this is a new one on me. Where did you come up with that info? I've never done any professional tuning, but I've NEVER heard that before. Not sayin' I'm too old to learn something, but.....help me understand where this came from....
Old Mar 30, 2009 | 10:08 AM
Pumba11's Avatar
Pumba11
If you run deisel fuel in your HD it will make white smoke. Don't ask me how i know!
