Won't start
Old Jun 5, 2019 | 01:43 PM
L0B0's Avatar
L0B0
1st Gear
Default Won't start
85 Harley. xls Roadster 1000 Ironhead
My 85 Harley Roadster turns over but won't start. Riding one day, everything ok, next day won't start. Engine turns over but won't fire. Plenty of gas.(even trid a shot of starting fluid) No spark at plugs. (new plugs) changed out coil to new one, still no spark. Any ideas on next step or what to try, any suggestions/help will be appreciated.
Old Jun 5, 2019 | 11:29 PM
David Ostrander's Avatar
David Ostrander
6th Gear
Sounds like your cam sensor or your points if you're running points.
Old Jan 17, 2024 | 07:53 AM
worldtraveler's Avatar
worldtraveler
No points and do you mean the Barometric sensor near the battery box ? how do i test it ?
Old Jan 17, 2024 | 08:09 AM
bustert's Avatar
bustert
these model years has issues with the ignition module. sometimes it will show up on the back as a burn or swollen spot. replace with aftermarket. i use the ultima or the compu-fire but there are others.
Old Jan 17, 2024 | 08:53 AM
worldtraveler
I did not notice i had rolled the page down to another guys problem which i did not read right i am still trying to fix mine.
Sean Gorham
Jun 2, 2019 07:42 PM
hendrix8zeppelin80@gmail.com
Jun 18, 2018 04:46 PM
wildbillshdsoftail
Aug 10, 2009 09:45 PM
grat
Nov 12, 2008 02:21 PM
K5BBQ
Oct 8, 2005 07:15 PM
