Loses spark
Old May 30, 2019 | 11:09 PM
Sean Gorham's Avatar
Sean Gorham
Stage I
Default Loses spark
Hi, I have a 1982 harley Davidson sportster, My problem is itll have spark then lose it. I'm not a mechanic only know basics, I have a book but cant make sense of it. Any help would be appreciated if I fdidnt provide enough info. Just ask and I'll try to explain more. Thank you.
Old May 31, 2019 | 02:30 AM
hscic's Avatar
hscic
it'll have spark then lose it....how are you determining this? What are you doing? Is it not starting? It is normally you have spark or you don't.
Old May 31, 2019 | 02:01 PM
TStephen's Avatar
TStephen
More info please.
Riding it? Does it die? Won't start? Have you physically checked for spark?
Old May 31, 2019 | 02:18 PM
Midpegs's Avatar
Midpegs
Default Not enough information
We're going to need a lot more information than that before even hazarding a guess at what's causing this intermittent fault .
Old Jun 2, 2019 | 10:39 AM
VAFish's Avatar
VAFish
Possible causes:
1. Loose Ground Wire
2. Loose Battery Cable
3. Loose Coil Wire
4. Bad Coil
5. Bad Battery
6.............
Start by removing, cleaning and re-installing your ground cables and battery cables.
Old Jun 2, 2019 | 07:42 PM
BoozeBeast's Avatar
BoozeBeast
Are you losing a spark at idle, or while riding? Are you allowing time for the bike to warm up? Are you sure it's the spark and not something like a clogged jet in the carb? Could also be a number of other things...bad coil, plugs, old wires, bad/loose ground...the list goes on.
hendrix8zeppelin80@gmail.com
Jun 18, 2018 04:46 PM
wildbillshdsoftail
Engine Mechanical Topics
Aug 11, 2009 07:12 AM
wildbillshdsoftail
Aug 10, 2009 09:45 PM
Darkhorse1
Aug 2, 2007 02:28 PM
Freeroamin
Jun 27, 2006 02:25 PM
