98" big bore
Hello,
Newer member to the forum. I have a winter project, converting an 2005 88" Fatboy to 98". Doing the newer cam plate oil pump etcetera. Looking at Andrews 37N low lift or Woods 555 high lift cams. Will have ported but stock 2005 valves which i believe had the newer bee hive springs. Undecided on pistons either -1.6cc or +3cc. -1.6 being 9.5-1 &+3cc being 10.1-1 I believe. I know compression and cylinder pressure are also important. I ride mostly in town. Although do several highway trips a year.
second question. I have the 5 speed transmission. If I produce enough torque can I change a drive gear somewhere to run at lower rpm on highway?
Thanks,
Thanks,
Agree with Scudda but assume guide seals will be replaced as part of the porting. I would further add that porting without increasing valve size is a mistake and counter productive to the plan. Why plan a build to increase performance but pass on one of the key performance enhancing modifications; not smart IMHO.
Forget about lower compression and consider the Andrews 57 cams at about 10.2 static; same profile as the 37 but with more lift; not OTT on compression but will produce a nice balanced curve with a good tune.
Complete the build and ride a while before considering a drive change to lower cruise rpms; lowering cruise rpms lowers rpms in all other gears as well.
88"/96"/103" heads are all the same casting but there was a redesign in '06 and the later heads do flow better. Valves are not bigger in the later heads but stem diameter was reduced from 5/16" to to 7mm and beehive springs were introduced in '05 along with POS valve guide seals. It doesn't make any sense to buy another set of heads and then spend the same amount to have them ported that you will spend to have your '05 heads ported.
Do the smart thing and have your '05 heads ported but not until you select a cam set and build around the cam.
I agree with djl. Have your stock heads worked. That's what I did.
Cheers!
