Reliability vs High Performance
Old Nov 24, 2010 | 06:47 PM
SpiderPig's Avatar
SpiderPig
Default Reliability vs High Performance
Can these be one in the same? Specifically I am after some information about high lift cams. As you can see in below what I have in my 06. A couple of years ago I blew a S.E. style lifter that took out my cam, cam plate and the oil pump. I was told back then that these S.E. lifters were problematic and this was the cause of failure. Recently I have heard that the high lift cams like these 585's are hard on the valve train and may cause another failure.
I am looking for some feedback from you guys that run these type of cams and looking for opinions if I should be redoing the build, and if so with what?
Old Nov 24, 2010 | 10:44 PM
Northside's Avatar
Northside
I have over 48,000 miles on a 95" Twincam with head work 10.5:1 pistons and .590 lift gear drive cams. I run the stock lifters, not the S.E. and have had zero problems with that bike. I'd ride it anywhere anytime.
Old Nov 24, 2010 | 10:53 PM
mkguitar's Avatar
mkguitar
1. Reliability
2. Horsepower
3. Cost
You get to choose two.
It's an old joke, but oh so true.
MK
Old Nov 24, 2010 | 11:26 PM
dohadex's Avatar
dohadex
Lightbulb Number line
Reliability}__-__-_Me_-__-__-__-__-__-_{performance
In terms of like...1 through 10.
Old Nov 25, 2010 | 01:42 AM
jbmunnoch's Avatar
jbmunnoch
Originally Posted by mkguitar
1. Reliability
2. Horsepower
3. Cost
MK
+1 that is the gospel
cheap, fast, or reliable you can only pick two
Old Nov 25, 2010 | 02:56 AM
Bluehighways's Avatar
Bluehighways
1. Reliability
2. Horsepower
3. Cost
MK
Oh yea . . . so true, so true
Old Nov 25, 2010 | 05:05 AM
dog155's Avatar
dog155
The more cubic inches you choose the less the motor has to work to carry the weight= reliabilty,performance,is built in.Costs can be kept to a minimum if you do your own work.
Old Nov 25, 2010 | 07:46 AM
Jinks's Avatar
Jinks
If the build work is done with quality parts & competent workmanship there's only one reason for less reliability with improved performance. The rider! Most riders are so impressed with the increase in power that they tend to punish the motor. Holeshots, burnouts, drag racing are all hard on your motorcycle. Sometimes it's difficult to resist the temptation, but sensible use of a powerful motor will result in good reliability. My FXR has been stroked for nearly 12 years. It's never given me a problem, & is still a seriously fast machine.
Old Nov 25, 2010 | 08:08 AM
lkr0's Avatar
lkr0
99.99% of the time this is true -- you get addicted to the power rolling burnouts/wheelies/getting it sideways/improper warm-up all have a bearing. If the motor is built well and you up the maintenance intervals (catch it before it happens) you can have a reliable fast bike--abusing any motor will cause premature failure--just my .02
Old Nov 25, 2010 | 08:25 AM
mtairy biker's Avatar
mtairy biker
I think for "HIGH LIFT" cams ..
I run S&S 585s I have S&S roller rockers and S&S lifters. so far so good . I think it is a reliable build
Stock lifter why??
NO roller rockers why not?
head work a must!
