Reliability vs High Performance
Old Nov 25, 2010 | 08:45 AM
DTTJGlide's Avatar
DTTJGlide
I've got a 103 with Crane 570 lift cams, took it apart to put in the SE cam plate & tensioners this fall at 68K miles, everything looked great including the cams & lifters. If you use quality parts & maintain the bike well you shouldn't have any problems, quit worrying & ride.
Old Nov 25, 2010 | 10:21 AM
SpiderPig's Avatar
SpiderPig
Guys, thanks for all the replies! The bike runs strong, just need to tweak the map a bit. I will be doing this in spring!. Regarding the question about why "Stock B lifters" I was told these are very reliable. Is that not the case? And is this the weak link in the build?
Old Nov 25, 2010 | 10:23 AM
MNPGRider's Avatar
MNPGRider
"cheap, fast, or reliable you can only pick two" LOL
I always liked the one, "The only thing faster than cubic inches is rectangular dollars."
Old Nov 25, 2010 | 12:15 PM
CEJohnson21's Avatar
CEJohnson21
Originally Posted by mkguitar
1. Reliability
2. Horsepower
3. Cost
You get to choose two.
It's an old joke, but oh so true.
MK
+1 Very true. You can carve it in stone.
Old Nov 25, 2010 | 09:06 PM
emwolb's Avatar
emwolb
i have a great combination in my 103, and i also believe that there is a happy meeting point between longevity and performance as long as you don't go overboard. i'm using the hd 259-E cams with .579" lift, and 10.75 compression ratio slugs. it's a comfortable and fast bike, for a dresser anyway.
Old Nov 25, 2010 | 09:19 PM
CT-Bagger's Avatar
CT-Bagger
Originally Posted by SpiderPig
Can these be one in the same? Specifically I am after some information about high lift cams. As you can see in below what I have in my 06. A couple of years ago I blew a S.E. style lifter that took out my cam, cam plate and the oil pump. I was told back then that these S.E. lifters were problematic and this was the cause of failure. Recently I have heard that the high lift cams like these 585's are hard on the valve train and may cause another failure.
I am looking for some feedback from you guys that run these type of cams and looking for opinions if I should be redoing the build, and if so with what?
If the engineers at HD thought they could wring out more ***** without sacrificing reliabilty don't you suppose they would have by now?
Stick with exhaust, intake, Power Commander or similar and external components.
Old Nov 25, 2010 | 09:33 PM
07FLHT's Avatar
07FLHT
HD is choked by EPA regulations, our changes like A/C's, exhausts, cams & a decent tune kinda "bend" those regulations!
Old Nov 25, 2010 | 11:13 PM
arealinvestor's Avatar
arealinvestor
You should be ok with a .585.After you install the cam make sure you check the the piston to valve clearance. I run a .660 lift in my bike, & bigger valves,but my valves geometry has been changed!!! You need better lifters.I would go with the Fuelings or the Wood lifters.I run the Wood's in my bike!!
SpiderPig
Mar 14, 2019 10:09 PM
Yeahmate10
Engine Mechanical Topics
30
Mar 4, 2015 09:43 PM
CigarDogHD
Aug 6, 2011 09:47 AM
FXDWG103JP
Exhaust System Topics
Jan 4, 2008 09:55 PM
KBES BAGGER
17
Feb 3, 2006 02:40 PM
