cam bearing size difference?
Old Feb 19, 2021 | 04:51 PM
roussfam's Avatar
roussfam
Collet, that's the word I couldn't remember, lol. I've used the old cams a couple of times. You don't pound the bearings in, you tap them gently until they're seated. You can tell when they're seated, sound changes. You can always pop them in the freezer prior to install as well. But if someone is not comfortable it's always better to use the proper tool and do it once. It's not a place where you want problems.
In Canada you can get a Blind Hole Bearing puller from Princess Auto (our version of Harbor Freight) it comes with different size collets, so if you're the kind of guy who does a lot of his own wrenching on various equipment, it's a good addition to the tool box. I think it costs less than the HD tool and you're not limited to one size of collet.
Jim
Old Feb 19, 2021 | 07:15 PM
djl's Avatar
djl
[QUOTE=MURPHCC1;19748753]Doesnt the new bearing have to be set at the right depth? An old cam bearing used to drive it in wouldn't set it correctly, no? Already ordered to puller/installer otherwise would have taken Kirby up on his offer, thats pretty special these days, props to him!!!
I don't think you mean "old cam bearing" but maybe "old cam"?? As rousfam says for a one off DIY install, tap them in, not rocket science.: Freezing them over night, liberal application of cam lube and they will pop right in.
Old Feb 20, 2021 | 06:41 AM
prodrag1320's Avatar
prodrag1320
Don't use anything but the correct tool
Old Feb 20, 2021 | 08:37 AM
roussfam's Avatar
roussfam
[quote=djl][QUOTE=MURPHCC1;19748753]Doesnt the new bearing have to be set at the right depth? An old cam bearing used to drive it in wouldn't set it correctly, no? Already ordered to puller/installer otherwise would have taken Kirby up on his offer, thats pretty special these days, props to him!!!
I see in the quote that the tool you ordered was a puller/installer, so you have everything you need then. Good luck. Using the proper install tool will ensure your bearings are square to the bore eliminating any chance of having them cocked when trying to install. I've used old cams many times for install but there's always a chance you could **** it up, pardon the pun, lol.
da Celt
Engine Mechanical Topics
Jul 13, 2015 01:53 PM
Hopper
EVO
44
Dec 4, 2014 09:03 AM
JJK16
Sep 13, 2014 06:26 AM
MILLER41143
Dec 23, 2011 06:13 AM
kennycoulter
Mar 12, 2011 02:18 PM
