Engine swap
Old Dec 9, 2022 | 08:28 PM
Harleyisstupid's Avatar
Harleyisstupid
4th Gear
Default Engine swap
I have an 03 Dyna police defender and a 03 ultra classic the dyna has had 88 switched over to 103 has a stroker and a stage 3 cam. the ultra classic not sure if it has anything done to the motor . can I switch my motor from the dyna to the ultra classic and if so what all would I have to do to be able to do that
Old Dec 9, 2022 | 08:33 PM
Max Headflow's Avatar
Max Headflow
It'l drop right in.. I used 2002 bagger cases on a 2000 dyna.
Old Dec 9, 2022 | 08:47 PM
Harleyisstupid
4th Gear
I don't have to beef up the oil pump in the touring. I had to in the dyna. ?
Old Dec 9, 2022 | 08:50 PM
Max Headflow
Why did you have to in the dyna?? Stock pump is the same between both.
Old Dec 10, 2022 | 09:29 AM
tdrglide's Avatar
tdrglide
If you beefed up the clutch in the dyna, you may want to swap that over too
Old Dec 10, 2022 | 10:35 AM
tdrglide's Avatar
tdrglide
Isn't the pump currently in the dyna coming over with the swap? No need to make more difficult
DaGho$t
Engine Mechanical Topics
Nov 26, 2019 08:14 PM
Bigpapa49
Screamin Eagle CVO Models
Jul 17, 2019 12:00 PM
Shockednutjob
May 19, 2018 03:00 AM
TO34
Nov 26, 2010 05:15 PM
Skyking75
Mar 28, 2009 05:35 PM
