Engine Light
Old Jan 7, 2023 | 07:19 PM
peteperrone's Avatar
peteperrone
Default Engine Light
Hello,
So the other day I rode a couple of miles to get gas to go for a dinner ride. After filling up and on the way home my engine light came on!
What would be the first few things to check before taking it to the shop?
Thanks!
Old Jan 7, 2023 | 07:20 PM
kel03's Avatar
kel03
See if it's thrown any codes.
Old Jan 7, 2023 | 07:22 PM
peteperrone
How do I do that?
kel03's Avatar
kel03
Have a read, https://www.fuelmotousa.com/p-29661-...ble-codes.html
Old Jan 7, 2023 | 07:42 PM
peteperrone
Thank You‼️
Old Jan 8, 2023 | 08:49 AM
peteperrone
So after checking codes here is what came up:
ECM
P0522
P0523
PN 001349-01
SPDO
B1213
PN 709001218
Other things that came up:
PN 41000341C
PN 40800131
PN 76000076C
i check the part numbers on H-D and could not find any of them.
Any suggestions would be greatly appreciated!
Old Jan 8, 2023 | 08:56 AM
Screamin beagle's Avatar
Screamin beagle
P0522 and 23 must be a typo...don't see them on the code list. What year, model, mileage and mods? Does it run any differently since the codes came on? Go recheck them and make sure you have them right then I would ride it, as long as its running like normal, and see if the codes come back.
Old Jan 8, 2023 | 09:51 AM
peteperrone
2018 street glide special
does not run different
have had problems with oil light on once in a while. Stop for 5-10 minutes then it’s off
here is what I found:
Old Jan 9, 2023 | 12:54 PM
peteperrone
So, I have checked again, same codes.
An earlier post I asked about my oil pressure light. https://www.hdforums.com/forum/engin...oil-light.html
Someone suggested the connections. I was thinking of changing out the pressure switch since it seems to be a problem.
Old Feb 6, 2023 | 09:30 PM
peteperrone
Thanks everyone! Took it to H-D, all checked out no problems.
