Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
Update , the tune in the ecm was corrupt . Took to an independent shop because I was down to believing the ecm was bad , they reflashed the ecm and that fixed it .
