cam timing question
Old May 21, 2021 | 06:34 PM
islander965's Avatar
islander965
Stage II
Default cam timing question
got a 2001 wide glide here with a running issue and I wanted to check if the cams are correct . if the 2 cam indexing marks line up and rear cam/pinion drive sprockets are indexed should the motor be at tdc on the rear cylinder? the front cylinder is on overlap and the rear piston is at tdc . many thanks...
Old May 21, 2021 | 06:37 PM
MURPHCC1's Avatar
MURPHCC1
Welcome aboard from Old Cape Cod!!
Old May 22, 2021 | 01:40 PM
BUILT's Avatar
BUILT
With timing marks aligned, the front cylinder will be on overlap and rear at TDC of compression stroke.
Old May 22, 2021 | 04:29 PM
islander965
Stage II
thanks for the response and the validation.
Sparra
Engine Mechanical Topics
Aug 13, 2018 01:32 PM
Stump juice 09 ultra
Feb 22, 2016 09:19 AM
ead78
Jun 25, 2014 06:59 AM
schmeg
Exhaust System Topics
May 13, 2008 11:21 AM
67xlch
Oct 24, 2007 07:37 PM
